there is an inline fuse holder beside battery
bobst2
Post by bobst2 »
well the bike is new to me there is an in line fuse holder right beside the battery it goes to the positive battery terminal. i think it is the master fuse to feed the system.but the previous owner has a heavy piece of wire in there can anyone tell me what type & amp fuse should be in there. it looks to be a stock looking piece push on connectors to the fuse holder :?:
SimonT-Dk
Re: there is an inline fuse holder beside battery
Post by SimonT-Dk »
bobst2 wrote:well the bike is new to me there is an in line fuse holder right beside the battery it goes to the positive battery terminal. i think it is the master fuse to feed the system.but the previous owner has a heavy piece of wire in there can anyone tell me what type & amp fuse should be in there. it looks to be a stock looking piece push on connectors to the fuse holder :?:
On my 900SuperSport, from 1990 - The Fuse is a 40Amp
And looks like this:
In Denmark it's called a Ceramic Fuse :)
Hope it helps you
bobst2
Post by bobst2 »
thank you i am shure that will work better than a hunk of pure wire
you`re shure that`s original ? Where does the wire lead to ?
I`ve never seen this on an original P750 wiring loom.
desmodave
year: 0
Post by desmodave »
one 7.5 two 15 amp!!!
sounds like an add on for something. You need to see what it feeds before anyone can suggest what size fuse to put in. Of course leaving the wire in is risky
