You might need to place a few washers under the screw head . or use shorter screws as the cover comes off
also made a crank turner , a piston stop and a dial gauge holder
I used a battery drill , a 4" angle grinder an electric welder , and a file and some crap that was lying around ( the barrel for the crank turner is a rover v8 valve guide
