ignition switch comapatibality
Does any body know if the ignition swith off of a 907ie will fit a 88 750 paso ?
- Skins
The ignition, tank and seat use three different keys. There is some information about key blanks in Registered User Menu (on the left of the screen) > Links > Ducati Paso technical sources > David Harvey's Paso Section - scroll down to 'Links' and find Ducati Owners Club of (GB) Parts Interchangeability List. There may be other leads to information in the same area.
thanks skins i just needed to know whether any of the locks were linked by a key... I need to replace a main ignition cylinder and having three different locks makes things much easier.
i guess i should be able to get keys made up from the lock numbers of the other items (seat and tank). not the easiest of tricks but there's no rush.
someone had mentioned keycutting service a while back so i chased it up a little myself http://www.motorcycle-keys.com/
- year: 1986
http://www.keys4classics.com
they were able to supply various blanks for mine as i have two different style of locks.
I got the one off of a 907 IE and worked on my 750. I did not have to do any modification to the wiring and the lock worked perfect. The only thing is that the top of the switch will seat lower in the hole. One thing I noticed was that the wires used on the 907 IE switch are lower gauge wires, So I added couple of relays. I think the main reason for the switch to fail in the first place is the high current and that should be handeled by relays.
- Finnpaso
- year: 0
Main problem in 750 Paso is, that near all current flows thru one pair of small contact inside key lock, so better add main relay to circuit, like i have done, so then key lock lives much longer time
907IE dont have such problem, cause there ARE 2 relays already. As everybody know, 907IE have much better electrics, than 750 and 906
Antti
Antti
