Hi.
The gears of my rev. counter are worn out and since I need to open it I thought I maybe should replace the bearings in the head as well, does anybody have the sizes of the bearings so i can buy them before I start dismantling the head?
From the 907 parts catalog:
Pos.......Code no........DESCRIPTION....QUANTITY
14........751101747........Bearing.............2
19........751102054........Bearing.............2
24........751731542........Bearing.............2
Håvard
Size of camshaft bearings?
Re: Size of camshaft bearings?
google says:
751101747 = SKF 6003/C3
751102054 = SKF 6004 - 2RSH
751731542 = SKF 6202 2RS
Havard, take a look here
http://forums.ducatipaso.org/viewtopic.php?f=2&t=4369
DOH! Tried to search the board but came out with nothing, searching Google didn't even cross my mind...
I knew i have seen the post with bearing sizes before so i tried to search the part number trough Google as G did, that was the first link they listed
Thanks both
Håvard
Thanks both
Håvard
Ken, are 751102054 & 751731542 really C3 ?
G
I'm positive they have to be C3, to allow for the heat generated in the head.
