42 mpg. 23,100 miles. Stock. Clean!
Never dropped, cracked, scratched, raced or abused. Adult owned, ridden, and maintained. No drips.
Starts great, runs great, drives perfectly.
Valve service just done (professionally), including throttle synch, new plugs, oil, axle alignment, etc. New BT023 rear tire with Ferodo Platinum brake pads front and rear. Shock professionally rebuilt - like new.
Upgrades:
Conti pipes
Voltage regulator
Barnett clutch kit (clutch, springs, cover, slave cylinder)
Motolectric kit (ignition, starter and battery cables).
Speedo cable
Optima battery
Reupholstered seat (Corbin)
Grips
The paint is absolutely gorgeous - shiny and original (factory stickers look amazing). There are a few nicks and a barely noticeable dent on the pipe. The seat has been recently reupholstered. The fairings are original with no signs of repair work. For you purists, I do have the factory clutch cover, battery/ign cables, and one Tommaselli grip.
Ask for the high res pics if you're interested.
$5000. I'll do the best I can to help ship the bike if necessary.
