I have a 1990 paso 906
the problem im having is the speedometor is not working what can i look for?
Re: I have a 1990 paso 906
Hello And Welcome. Take the nose cone off (6 screews), unscrew cable where it goes in speedo. check inner cable turns when front wheel turns. Hopefully its the cable snapped or the drive broken. Either are cheap and easy to replace.
ok thanks,ill try that
