Googled the 69921511A p/n and it comes up here: http://www.store.commoto.com/product_in ... s_id=71923
looks like we can get it for all our bikes?
doug
Oil Pressure Sensor Replacement?
- Stingray230SX
Re: Oil Pressure Sensor Replacement?
1992 907ie #1473 Nero SOLD
jayh
- year: 1986
Land Rover discovery TDI 300 is also a direct swap.Your local auto parts store should have a aftermarket catalogue full of senders and their switching modes and thread pitches,I just went down the list until I found the correct mode and pitch with a price that matched my wallet.
J
Mine is off a VW golf ..... I think . Like Jayh I wandered down to the local parts guy ( Jim @ Allparts ), perused the catalogue , 10mm taper thread , nc ,6.3mm spade & 7 lb crack.....mmm a Vee Dub huh. There were 1/2 a dozen that would have done if I could be bothered changing the terminal on the harness to suit , and I figured that the operating pressure wasnt vital as long as it was ballpark , I mean if you are supposed to have 60 psi it doesn't matter if the red light is telling you that you have less than 7 psi or less than 4 psi , either way your history.
If I set the idle to low the oil pressure light on my guzzi winks at me like a homo in the toilets ... probly harmless enough but unnerving all the same ( I can get it to idle at 4 -500 rpm ) and anyhow its not 1/2 as excitable as the charge light which blazes away at anything below 1700rpm .
fuck
I hope I havnt got them mixed up
I dont do italian
gen ... charge light , folle.... blinkers , luci ... neutral and olio for oil pressure..........I think
I dont do italian
Mc tool wrote:
I dont do italian![]()
gen ... BATTERY CHARGE , folle.... NEUTRAL , luci ... LIGHT and olio for oil pressure..........I think
Gabriel
Paso 750
Elefant 750 Monofaro '88
Elefant 900 Monobraccio '89
Elefant 750 pure off '85
SS 750 '92
Paso 750
SS 750 '92
Hi Doug, well, you could always buy the OEM part from Ducati as well. My point when I started this thread was twofold:Stingray230SX wrote:Googled the 69921511A p/n and it comes up here: http://www.store.commoto.com/product_in ... s_id=71923
doug
1. I didn't want to wait weeks or more for the part.
2. I didn't want to spend over $30 on a friggin' oil sender!
I don't know how long you've been a Ducati owner, but finding critical parts on semi-permanent backorder (Like oil filters! 1993? Anyone else here remember that one?) is enough to make me want to find alternatives any time I can. (EDIT: If Ducati NA ever runs out of oil filters AGAIN, go to NAPA and order a filter for a Simca. No, I've never heard of one either. But I've used an oil filter from one!)
I now have a section of my toolbox devoted to leftover sensors from this project! So much for saving money! Ah well, it was fun, figuring out a different way...
