The new set is on the way, but I can’t find the spec for the end gap in the workshop manual. What are the gaps for each ring? Thanks!
Yep - 28MM wide angle lens on an Olympus SLR. I also have a 24x24 softbox light I was using. Light and depth of field give the effect. Photography is a hobby of mine. When I get on my personal PC, I'll post some more photos.paso750 wrote:how did you make those photos ? It looks like a miniature model![]()
As for the rings, they are already on the way from Italy.silverfox wrote:If you can't afford the genuine rings,
You wouldn't happen to know the part number? What model Subaru they fit?Mc tool wrote:For those of you with 904cc engines subaru ( or thier after market suppliers ) do a 92mm ring set thay fits perfect and you get 2 sets for nz$80 instead of nz$600 for oneset of duke ones
