measures Paso 280mm brake discs
Anyone have at hand the internal diameter, mounting hole diameter, disc thickness and height of the brake disc (the area which is touched by the brake pads.
I have the measures at home but maybe someone is faster. I was just wondering as some Kawasaki brake discs look similar.
Gerhard
Finnpaso
year: 0
Post by Finnpaso »
"height of brake disc" = that measurement, what is touching to pad: 42mm
"inside hole diameter": 136mm
"thickness": 6mm
"distance between screws"(to another side): 154mm
"munting holes": 8mm
Antti :thumbup:
