Firehawk75:
better check to see if it is indeed available. At a lot of places with web sites you can order on the web all day long but then you may get an e-mail stating that the item is not available or on back order and then they will "let you know" when it comes in. I contacted Omaha a couple of weeks ago and they told me the the lens was not available.
du907
Turn signal Lens for front?
Re: Turn signal Lens for front?
just as a general sidenote
when having a dealer or shop check availability for parts as old it`s always better to look up the parts catalogue and write down all part numbers before. I may be wrong but I think the Supersport is the earliest model in Ducatis electronic parts program, all others are only on microfiche. So some may reply they don`t have anything just because they`re too lazy to dig up the old microfiche reader or simply because they don`t have one. They don`t have any problem checking availability of part numbers. Getting the part numbers is a shop`s problem.
- persempre907
The 907 is in the electronic parts program, the 906 and 750 does'nt.paso750 wrote:I may be wrong but I think the Supersport is the earliest model in Ducatis electronic parts program, all others are only on microfiche.
I don't know about the availability of the lenses in Italy.
I bought many ones some time ago and don't need them.
If someone is interested, I could ask to a local dealer.
- Derek
- year: 1994
I ordered a pair from the eBay seller and received them last week. The bike looks so much better with them fitted
I have a new set of lenses that I'm putting on ebay tomorrow.
