looking for source for new 906 igntion pick up coil
bobst2
if you know of a suitable replacement or north americian supply please let me know
Re: looking for source for new 906 igntion pick up coil
The pickup coil is a very common item used in several European cars, I bet on ebay you can find it.
I remember going to a Fiat dealer with the old pickup (was for a "Digiplex" P750, but the set up is the same for the P906) and finding a matching replacement for "pocket change".
bobst2
has anyone else used a fiat pick up coil as a replacement. i looked on the net early to late fiat uno part looks the same any info would be greatly appreciated. no dealer in my city that would have any old fiat parts to compare it with all help would be greatly appreciated
bobst2
found the sensor pulled mine out and confirmed part # SEN-8E bought one out of florida usa
for 30 dollars u.s.
ebay item# 330556846238 was told by italspares in australia was around 240 AU dollars from ducati
thanks for the info
for 30 dollars u.s.
thanks for the info
- persempre907
That isn't a FIAT replacement.bobst2 wrote:has anyone else used a fiat pick up coil as a replacement
It's the same pick up coil built by Magneti Marelli and used both on many FIAT group's cars and on many Ducati.
bobst2
well got it and installed cured the problem bike seems to run fine again
- persempre907
