Hi guys it's a long time i don't write, but last week i went in box just to put things in order and i find out a lot of good parts to sell...
here's a list
-Electric elements(Cdi, rectifier, spark plugs, rele's, starting switch, fuel pump etc)
-2 engine crankcase
-oilpump
-lightwheel
-albero motore(engine drive shaft?? i don't know if it's the right translation)
-clutch blocking key tool
and some other little stuff.
Ask me for any question and if i find some other parts i'll post it here.
kind regards
Piero
last parts for sale...
Re: last parts for sale...
if its the output shaft, its called a countershaft where the small chain sprocket goes-albero motore(engine drive shaft?? i don't know if it's the right translation)
If its the main shaft part of the trans it is the mainshaft
Crank ? crankshaft, the part the pistons drive
yes it's the part in the crankcas that drives pistons...
- persempre907
Albero motore = crankshaft.
