Seems that I made user account here some time ago so here's finally my first post
Here is some history of the bike. The previous owner had bought the bike autumn 2008 and he had kept it in storage to ride it next summer. He had run it periodically during the winter and when the ice was smelting he began to service it for the spring. He had serviced the carburettor and done some other maintenance work for it. When he tried to start the bike it would not fire up. He started to look for fault in the ignition side guessing that spark was too weak. He had tried to start the engine many times for long periods and this had wore the starter motor and sprag bearing down. He gave up and decided to sell the bike so I picked it up.
I bought the bike in the spring of 2010 and my intention was to make it run and ride it for the summer. I got the engine to fire up after servicing starter motor, sprag and the carburettor. Seemed to me that the fuel clog had been jammed up and engine didn't get fuel. After replacing the fuel lines and giving some fuel from separate container engine fired right up. I started to put the bike back together when I noticed the fuel tank was leaking. Bike had been flipped over at some time of its life and the upper support of the tank had been torn at that point or it had broken a little bit later. I didn't want to run a bike that spills fuel all around and it was already autumn so I decided to leave it to sit for the winter.
Last year I got the tank fixed, but I had a lot of other things to do so Paso sat in the garage waiting for better days. I tried to get it on the run but I noticed the water pump was leaking quite badly so I decided to leave it for then. Oil is leaking also from somewhere, I have to find the source for that also.
Now the days are getting longer here in Finland and I am urging to get the bike running when the weather gets better. Today I pulled it out from the back of my garage and took a look at it
To do list:
-Clean tank (rusted from inside)
-Fix the water pump (leakage and one blade missing from the impeller)
-Find source for oil leakage
-Set up carburettor
-Find new ignition coil (broken fastening for ignition lead)
-Replace cam belts
-Polish
-Some surprises
I guess I will be asking for some help here in the future, so here is the first question: What are these silencers? They seem to have original Ducati part numbers but also a mention that they are not for road use. They sound absolutely fantastic though
Some pictures: http://kuvablogi.com/blog/21657/12/
