Andrew
Just wondering why bother, if the battery has a breather/overflow outlet it should have come with some plastic hose of reasonable length to run down and under the engine for ventingAndrew2 wrote:I'll check the regulator.I think I have a good spare ( of course....being a Ducati owner I would have a spare regulator![]()
).The catch tank idea looks like a good one too.
Andrew
I`ve always signed in short. With the amount of posts in the forum and the insane amount of emails written per year I`d have to write my name 20.000 times....why does no one put their real names on the end of posts on the internet.
ducinthebay wrote:I have never heard of a Sport frame cracking, anywhere. I would assume the strut was added based on the development of the 851 which has a similar frame structure around the head area. I would assume that the added strut stiffened the frame for situations, like heavy braking.
If you add it, I would suggest doing it the way CroMo bicycle frames are made and just braze it in place. Cut the seat stays off an old bicycle and your in for cheap.
Hindsight...what a wonderful thing.I would still have my F1 with a bit of hindsight.It's a strange thing how certain bikes become collectable.The F1 was never a great bike in my opinion.The motor had less power than the Sport.The 16" front wheel made it extremely dangerous without a steering damper and even when I put an 18" front on it still wanted to spit me off without the damper wound up.But being a low volume model it's now collectable.Go figurebmw851 wrote:Or dare, dare, to just leave it, they will be collectable one day and paticualrly a unbutchered 1st Model in original condition, may take another 10 years though![]()
As Phil says it is an easy thing to get done, but...................................
This was always a more about saving a bike that was left to rot, than owning one to ride project, no?
Yep that's right...
I mean who would have ever thought a Dramaor any square case model in original condition would become so sort after one day, all they ever did back in my day was drop bigends and valves when ridden the way they should be, ah hindsight what a wonderfull thing.
And you should know better then anyone, you do still share a shed with one don't you![]()
Peter
G'day Claude,907pasonut wrote:what a great post, and interesting restoration,![]()
Andrew you have undertaken a major project...your mate must of been living next to the beach, or very close to a cement factory, or both
I can sympathise with your dilemma as I find myself in a tight financial situation as well, but also keen to finish my 851 project...
hi Andrew, I wouldn't call it a restoration, the bike itself is in very good condition with 13k km on the clock, its going to be a single seat conversion (project) with the rear aluminium frame, hi-rise carbon pipes and ceramic coated header, rear carbon hugger, a nice corbin seat (thanks to Gerhard) and quiet a few other cosmetic changes including chain, sprockets, chip, adjustable cam pulleys, clutch slave cyl, braided lines, and last, new belts and rubber, I have most of the bits, just have some personal issues at the moment that are causing me grief and draining me financially, but it should be sorting itself out in October...Andrew2 wrote:
Do you have a link to your 851 restoration.It sounds very interesting.
Andrew
