The other issue is that there seems to be a bit of wear in the throttle shaft/ carb body ... is there a replacable bush in there ? And where do you get o/haul kits (every time I look for any sort of FCR kit I get install kits inc carbs for various bikes ) I need float bowl seals acellerator pump seal and diaphram and the little piece of plastic that sits above the ball valve in the acc pump . These carbs were supposed to be newly overhauled before I got them , but plainly havn't and as Im sick and tired of being fucked about and lied to Ill just sort them myself . If any one can point me to a service manual or even a decent parts diagram I be grateful
