I'm rebuilding the DCNF. Attached is a picture of the gasket that came with the kit and it looks just like the one I took off. But, is it OK for the gasket to block off the holes circled in red in the second image?
http://i1149.photobucket.com/albums/o60 ... /Carb1.jpg
http://i1149.photobucket.com/albums/o60 ... /Carb2.jpg
Carb rebuild question
1988 Red Ducati Paso 750
1999 BMW R1100S
1999 BMW R1100S
Re: Carb rebuild question
The gasket doesn't actually block the holes - they are transfer holes, with a channel between them that is cut into the body of the carb. With the gasket in place, there is clearance for air (or air/fuel mixture, I forget the actual flow of the enrichment circuit) to transfer between each set of the two holes.
Thanks for the reply. I noticed that there were matching passages in the casting of the top of the carb and wasn't sure how much volume was needed for the clearance.
1999 BMW R1100S
1999 BMW R1100S
