öhlins overhaul; anyone?
Brutus
Re: öhlins overhaul; anyone?
Post by Brutus »
Ok, got the new parts, see plastic bags:
First I had to find a way to take the preload adjuster apart. Couldn't get the piston out. Solved the problem with a little piece of aluminium, see above on the left. Picture down installed:
Fitted new filter oil:
Made an alu block to clamp the axle. Heated the end eye bracket and managed to take it off (just turn it ccw):
Next the adjuster wheel that needs to be replaced. Again managed to take it off, but with a little surprise.. The ring behind the rubber adjuster wheel is damaged. Part is allready en route :cool:
micklm
Post by micklm »
Hi Brutus,
Great photos! Thanks for posting them :)
Regards,
Mick
Brutus
Post by Brutus »
micklm wrote:Hi Brutus,
Regards,
Mick
Tx. Till a couple of weeks age I couldn't find allot of information about the öhlins and decided to take it apart myself. All the parts I needed where available. I'm still hopefull that it'll come together again. Still waiting for the spring with a fresh coat of paint. :mrgreen:
jayh
Post by jayh »
Just out of curiosity Brutus, are the part numbers matching up with the spec sheet I posted ?
Looks like you're doing a great job,it will all go back together a lot easier than it came apart. :thumbup: J.
Brutus
Post by Brutus »
Jay, I've scanned the note and the specsheet that the dealer supplied.
The specsheet is rather of poor quality. Send me a pm if you want a pdf-file. Checked with the specs you've posted and they match:
SPECIFICATION CARD SINGLE SHOCK
Code No. DU5082 replaces DU5081
DUCATI 750 PASO 86-88
Total Length 365 mm , Stroke 78 mm
Head 570-05 , Body 1010-07 , Shaft 1002-02, End Eye 1054-03
Internal Spacers 1069-04,-05 , Shaft Jet 1021-03, Adjustment Valve 1055-03
Valve Stop 519-02 , Piston 514-11 , Adjustment Shaft 566-52
Shims :
Compression.....................Rebound
525-38 ..........................530-34
525-38 ..........................525-30
530-34 ..........................525-26
525-30 ..........................530-23
520-26 ..........................525-21
525-23 ..........................525-19
525-20 ..........................530-18
525-19 ..........................578-01 (2 X)
Spring 1099-05 , Preload 25 mm , Spacer and eye 1018-09 , (Spacer and eye 1018-09)
Hydraulic pre-load adjust 1042-04 , Spring Clip 629-01 , Bump rubber 564-01
Gas Valve 603-01
Piston position 35 mm , Rebound Click 18 , Gas pressure 20 bar
Léon
jayh
Post by jayh »
Brutus,Thats good that they match up.It means the information is most likely correct and up to date,for any of the other ohlins paso riders that need it. J.
Brutus
Post by Brutus »
Job done! Picked up the spring. Got some loctite 2701 and put it all together again. :lol:
It's been a long time since I've posted something on the forum the last time, but now I have a question.
Does anyone know where to find the spring 1099-05 and the hose 1042-04? (preferably within the EU)
I just had a DU-508 rebuilt but the shop who's an official Ohlins partner says they can't get these anymore.
Finnpaso
year: 0
Post by Finnpaso »
Hi! At least here in Finland Öhlins maintainer have all needeed spare parts to that 750 Paso Öhlins and it is quite cheap also open and rebuild, something about 60-70€:s and they can also make new steel braided hoses to it. :thumbup:
907IE -91 red/metal grey
907IE -91 red
I should have sent it to Finland then as the rebuilt cost €360 here. Also the spring isn't available anywhere in Germany. I'll have it powdercoated.
ludiluka
year: 1985
Post by ludiluka »
Does anybody have data of stock spring N/mm and lenght of the spring. I have suspicions that spring on my shock was changed
