Fairing bolts on eBay, any good?
mr blamco
Post by mr blamco »
Finally getting some time to put this bike on the road (sitting in the garage since I found it this past spring). PO took the fairing apart years ago and lost some of the bolts and many of the rubber bushings are in crap condition. These bolt kits aren't cheap but I'm willing if they're quality. If anyone has experience with these kits please let me know.
http://www.ebay.com/itm/NEW-88-89-90-91 ... 3a6e42085e
I know I'll have other questions but I've already found good info in previous threads. Can't wait to ride.
ahdoman
Re: Fairing bolts on eBay, any good?
Post by ahdoman »
I've been wondering the same thing since a couple of my rubber inserts are rotten. The Paso 750 has a total of 24 of those rubber grommets if you include the oil coller covers, 14 if you don't. In the picture they show 18 of the grommets.
1988 Red Ducati Paso 750
1999 BMW R1100S
randtcastell
Post by randtcastell »
I believe this ad is just for bolts, nothing else, and they are incorrect in terms of head and construction. Original fairing bots are not button heads, and are hollow, not solid. Those bolts are heavy and high profile and if you want them, they are available from McMaster-Carr catalog for about $1US each plus shipping. ;)
1987 Ducati P750
1973 Honda CB450
2022 KTM RC390
The bolts on ebay dont fit any Paso forget them.....
Get them cheap as stated at McMaster Carr
Foxtee
Post by Foxtee »
Got a similar set of these on my Paso for the couple of years now ..no problems, still look good as new
1990 750 Paso
2011 Suzuki Bandit 1250 S
allenmarton
Post by allenmarton »
nice posts and forum.thanks for sharing...
Witzie
Post by Witzie »
If you need rubber bolts, I use these:
http://www.rawlplug.co.uk/index.php?opt ... &Itemid=34
RNT-M6/16
I bought them at a Fabory shop.
Kawasaki Z700 1987, Kawasaki ZL1000 1990, Ducati PASO 750 1990, Ducati 900ss 1994,
Kawasaki ZZR1100 1993, Ducati Paso 906 1989
delagem
year: 0
Post by delagem »
randtcastell wrote:I believe this ad is just for bolts, nothing else, and they are incorrect in terms of head and construction. Original fairing bots are not button heads, and are hollow, not solid. Those bolts are heavy and high profile and if you want them, they are available from McMaster-Carr catalog for about $1US each plus shipping. ;)
Can you provide the McMaster Carr part number? I live in that catalog at work, and have tried numerous times to find an exact match. Never found a bolt that had the correct size head. All very similar in size to these FleaBay ones.
For what it's worth, that eBay kit does at least include bolts, washers, and wellnuts. (I know nothing of this kit personally, just reading the ad)
eBay ad wrote:This is a complete kit includes all the bolts and washers needed in order to reassemble all your fairing plastics.
This kit includes the screws, washers, speed nuts (as required), well nuts (as required), lock nuts (as required), and push pin rivets (as required) to install the fairings.
fuck the ebay kit it don't fit You will have to close up all you mounting holes and redo them. It is a nice kit it just don't work move along nothing to see with the ebay kit :banghead:
randtcastell
Phil:
This is as close as McMaster Carr gets to our fairing bolts. They are the wrong head, and are solid steel, but they are closer matches than any thing else I've found, and they do work.
1: 92137A535Metric Flange Button Head Cap Screw Alloy
Steel, M6 Size, 20 Mm Length, 1.00 Mm Pitch
2: 92137A644Metric Flange Button Head Cap Screw Alloy
Steel, M8 Size, 20 Mm Length, 1.25 Mm Pitch
:beer:
1987 Ducati P750
1973 Honda CB450
2022 KTM RC390
++ :beer: :beer: McMaster Carr
