Hi all. Apparently, I have one (or maybe 2) warped rotors on the front of my '92 907ie. Pulses badly when braking...... Does anyone know if these are the 320mm rotors? I know they're bigger than the ones on my old '91 907ie...... Are these readily available? Are they interchangeable with rotors from the 900 SP/CR? HELP!!!!
Gary
sungamma@aol.com
907ie brake problems.....
pencilbeam
I had the same problem on my '92 907. They should be 300mm and are interchangeable with other models. My replacements came off a 748!
Keep a watch on eBay, but aftermarkets are available. Try:
http://www.ducati-gowanloch.com/brembo.htm
or
http://www.powersportspro.com/partsfish
or
