Rear Footpeg fix
- year: 1989
Rear Footpeg fix
Hello people. I went for a ride on the Paso the other day and noticed that the passenger pegs are not staying up when not in use they vibrate down within a minute of start up, is there any fix for this. This is the first time i have ridden this year and they were not a problem last year. It has just started to happen. Thanks in advance for any tips or tricks.
Re: Rear Footpeg fix
They are held up by a spring loaded ball that locates the peg . Pull it to bits and clean all the crap out , and I put mine back together with really stiff grease ( like tar twere ) . If they are really floppy the pivot holes can be drilled/filed to fit a larger pin ( 11/32" ) , as can the locating bearing hole , same for the main pegs . If they are getting a bit saggy/ loose its well worth the effort. Check also where the peg bears against the bracket ..... sometimes a few wacks with a hammer ( dissassemble 1st ...... the peg not the hammer ) can reshape the ally so as to reduce the sag. If you do try to reshape ally make sure you have the work well anchored and use a large punch . By placing the end of the punch on the lump you want to flatten your gauranteed of actually hitting the bit you want .... not the bit next to it
. If you make cleaning / regreasing a yearly event you will drastically reduce the wear in the pivot holes
- year: 1989
Thanks Mc Tool that will be the project in the morning while im waiting out a cyclone here in WA cheers
- persempre907
A cycloneHarry wrote:Thanks Mc Tool that will be the project in the morning while im waiting out a cyclone here in WA cheers
Stay indoor. Good luck!!!
- ducinthebay
If the detent ball is completely knackered, bring the parts to a decent bicycle shop and they will get you a ball bearing that will fit.
Like McTool said, take it apart, clean it up, pack it with thick waterproof grease to have it live a long and happy life. Don't spray the footpeg pivot directly with water when cleaning.
yeah ! certainly worth waiting for
