Ducati photos
Re: Ducati photos
she's a beautiful girl for sure........
Andrew2
Re: Ducati photos
That's a great looking Sport Daniel.If mine looks half that nice when it's finished I'll be happyDanielmc wrote:Nice bike Phil!
Here's mine. Nothing radical - I'm thinking that this is the bike Ducati should have made (apologies to purists and no offence intended!): Dell'Orto 36 carbs (thanks Phil & Maico) 17" wheels, M1R forks, 320mm discs and later type, 65mm mount calipers, carbon front mudguard and rear hugger, Öhlins rear shock.
Andrew
Andrew2
Re: Ducati photos
Cool bike Phil.Do you have any close up photos.What are the rear sets from?.ducinthebay wrote:And my current Sport.![]()
Next steps, Black 4 piston calipers, black caliper in back, new mirrors, some pipe wrap by the brake M/C, a fork rebuild, and switch to a 4.5" rear rim with 160 tire.
Andrew
- ducinthebay
Re: Ducati photos
Andrew, Your bike and mine are very similar, except I am running 300mm rotors, and a few other bits.Andrew2 wrote: Cool bike Phil.Do you have any close up photos.What are the rear sets from?. Cheers
Andrew
I posted pics a couple of months ago under this topic:
http://forums.ducatipaso.org/viewtopic.php?f=13&t=5455
The rearsets are stock, I just cut a bunch off the right hand one and moved the master cylinder because it hit the exhaust I have on it. The pegs are cheap Emgo or some such thing. (light, and they work)
- bmw851
- model: other
Re: Ducati photos
DanielDanielmc wrote:Nice bike Phil!
Love the way it all looks, well done, and does look very OEM.
Peter
Andrew2
Re: Ducati photos
-Donnor bike : Cagiva Alazzurra 350
-Frame modified for mount cantilever schock system.
-Hand made front bracket
-Rear frame totally new construction
-TT2 Alumium footrest.
-Ohlins Rear schock
-851 Front fork
-Monster wheels
-Brembo cast iron rotors
-SS Brembo calipers
-Brembo radial PR 19 brake pump
-ST2 clutch pump with cnc machined regulable and folding lever
-Frentubo Kevlar /ergal brake and clutch lines
-Ergal cnc machined clip ons
-851 SP3 front mudguard
-Floating rear brake caliper (Superlight system)
-TT1 verlichi aluminium swingarm
-RAD 02 rear mudguard
-RAD 02 Montjuich TT modified solo seat in glassfiber
-RAD Pantahstica glass fiber fuel tank (Wolfman design) with ergal gas cap.
-Ducati single race front fairing
-916 side stand
-PASO 750 engine with F1 Montjuich rear head (for rear mount carburetor as Pantah), ported heads , big valves, TT2 camshafts, lightened flywheel , blueprinted engine.
-Monster 1100 EVO oil radiator
-Dell’Orto PHM 41 carburetors
-Domino quick open gas throttle.
-2.4 Pederccini ignition units
-Dyna Coils
-NGK race spark wires
-Hand made race wiring
-LIPO battery
-Montesa rear light.
-H4 high/low beam front light 10 cm diameter
-851 rev counter
-RR oil thermometer
-Wolfman 2 in 1 exhaust system
-Spark GP type megaphone.
- bmw851
- model: other
Re: Ducati photos
This one is sitting in Japan waiting for shipment, will be available from Old Gold Motorcycles here in Oz around May/June could be an interesting project, has some mods but looks to still have the Weber.
- 165458_533602840023718_1873457745_n.jpg (157.2 KiB) Viewed 28378 times
Re: Ducati photos
what you can see is a Mikuni carb manifold and float chamber...but looks to still have the Weber.
- bmw851
- model: other
Re: Ducati photos
Thought I may as well post a pic of mine as of last Sunday 28.04.13, love the look of some of these bikes, keep the pic's coming.
