Regards, Paul
Yup, that happened to me too. 'The horror, the horror'englishstiv wrote:Paul - be careful as you remove the bolt head and screen in case the solder holding it in place has perished/worn away as the screen will fall into the sump area and is a pig to fish out..........I know I spent two days fiddling with it as mine had already fallen away.
I cant remember as well, but I tend to think you have to loosen the bottom screw/bolt to remove the screen/strainer ass...perhaps paulmozzi could answer thatpaso750 wrote:a stupid question, do you have to remove the screw on the bottom to get the oil screen out ?
I had it done the past time so I can`t remember![]()
