Has anyone fitted the right angle valve stems to there 907? The next thing on the list for the 907 is a new set of tyres, and was thinking of replacing the straight valves with the right angle type. Have a look at eBay Item number: 161022711747 if you are wondering what I'm on about.
The other $90 question, is what size is the hole in the wheel? There appears to be 2 sizes available, 8.3mm and 11.3mm, but which is the correct one? I'm siding with 8.3mm, but Murphy says if I buy that size, it will without a doubt be the other
Cheers.
Nick.
