Hi to all,
I'm searching for a original chip dump from the 907 because i want to try to change my ECU to some newer Marelli ECU.
Does anyone of you have sutch a file or know were i can get one?
a dump from original chip
Re: a dump from original chip
I have spare standard and baines chips you can borrow for copying. Where are you?
Chip f 10 bucks:
http://www.ebay.com/itm/92-Ducati-907-I ... 8d&vxp=mtr
that`s the leaner US chip, isn`t it ?
- persempre907
Yes, it's so.
Tamburinifan wrote:Chip f 10 bucks:
Do us all a favor...DON"T BY YOUR PARTS FROM THESE KIND OF OPPORTUNISTIC SELLERS
Talk to Ed or Ian or Steve or one of the more reliable sources
- du907
Magicfinger95,
You can have a look at these. I got the "Customchip" from a fellow in the UK. It is what I'm using in my 907 now. I am pleased with it. After setting my TPS, balancing the throttle bodies, air screws, mixture screw in ECU, I needed a chip that was richer than my US chip. This one did the trick for me.(I have aftermarket pipes too). The "DucatiEuro" chip is the standard chip used in the European model.
Use them at your own risk. They can at least get you started. I don't know what any of the information in the files are. I had them programmed into a couple of chips and like I said, I'm running my bike on the "customchip" one, have been for years.
du907
907customchip.obj
907DucatiEuro.obj
You will need to send me a message on this board with your e-mail and I will send the files to you by e-mail.
du907
907customchip.obj
907DucatiEuro.obj
@900streetfighter : thanks for your offer, I'm from Austria but I don't have any tool to readout an EEPROM either copy it.
Thanks to all other too..
i hope @du907 files will work for me
if my adaption works i will post the results.
