Add on wind spoiler
Add on wind spoiler
Anyone has one?
Is it doable on a 907?
Been looking at the Varios here :
http://www.wunderlich.de/shop/catalogse ... lt/?q=wind+
Could anynof those work?
Other options?
A solution not involving drilling etc, just f occasional touring trips, would be best.
Other options?
- englishstiv
Re: Add on wind spoiler
I have recently purchased a top front fairing for my 907ie which has a perspex screen modification I am not sure which piece of kit you were looking at on that site but I do know that my adapted item is a perfect fit easily removed and replaced with a few screws as fitted normally and was a awful lot cheaper than the ones on that site that I was able to view.
my item was from a dealer in Holland ( sadly his only one in stock ) but it was a properly manufactured item so they are out there.
I have also seen them on ebay.
DUCATI 907ie 1992
Ducati Streetfighter 955 V2
Sounds promising!
Any brand on it or name to Dutch dealer?
eBay link?
A pic would also be extremely helpful!
Does it relive you from wind pressure & turbulence at 130 km/h?
eBay link?
- englishstiv
My paperwork is buried under a mountain of trash in the garage so can't get a link but these may inspire you a little..... I know these are a bit pricey but you could also get inspired by looking at the last thread shown and maybe utilize a second hand top fairing.
http://www.bikescreen.com/products.asp?cat=85&pg=8
http://www.diopa.com/shop/shop.html
You could also consider using a Hayabusa screen cut down ? (It has been done) there are lots of options shown on here
http://forums.ducatipaso.org/viewtopic.php?f=9&t=2163
DUCATI 907ie 1992
You've surely found alot, THX!
Could this
http://i241.photobucket.com/albums/ff28 ... d0_1_b.jpg
be the Diopa?
That w a http://www.givi.it/Screens--spoilers/Un ... reens/AF49
night be the one combination that really work, the Paso screen being so low.
Neither pretty nor easy detached, though...
Wonder what Gustafssons looked on a Paso.
Could this
be the Diopa?
Duc750
- year: 1993
On ebay UK at the moment there's a 906 top fairing and an ermax screen for sale - could be the cheapest way to do it as you have to permanently mod the nose cone for a screen to fit
You mean this:
http://item.mobileweb.ebay.co.uk/viewit ... 0820367292
Ermax is abit, eh, unappealing.
Wonder if this could work or if it's too small:
http://www.wunderlich.de/shop/wunderlic ... -6223.html
Duc750
- year: 1993
A screen on a Paso is always unappealing so why not buy someone elses's mistake cheaper than making your own !
That`s why I want one to clamp on.
The eBay 906 screen looks like the same size & form as the original.
Duc750
- year: 1993
try aerotrim i have one stuck on to my BMW and thats not too bad
Failing that MRA
Failing that MRA
Aerotrim & MRA involves drilling etc.
Since the 907 has a sort of shield a la the above 2, maybe an extension of the rear of the original to help
wind a bit higher would be best?
Leaning towards the curved Puig atm:
http://www.louis.de/_204050cb4404a34cc8 ... E=10006546
What is the most common & correct way of measuring/
describing your windshield radius to a shop?
Assuming they haven't info of Paso but surely another model
would be close enough.
