clutch springs
a330us
clutch springs
Post by a330us »
Hello, when I bought my paso last week the owner said he couldn't find one of the clutch springs and sure enough one of them is missing so was wondering if anyone in my area of the country has a old one laying around that i could buy? I can't find the torque settings for torqueing down the clutch springs since that part of my manual is missing and also the height of a good valve spring. I can't really see any wear since bike only has 4900 miles on it and also what do you use to clean the plates? All of my experiences have been with shaft drive and auto style clutches in BMW's so this is a new world. Thanks Arch.
englishstiv
Re: clutch springs
Post by englishstiv »
Hi there
As always with new members reading this and those of us on here years such as yourself :fart: :thumbup:
I would suggest please use the search button you will be amazed at the wealth of knowledge available pretty damn quickly just use as many words relating to your issues to get the best results.
Hopefully this may help
http://ducatipaso.org/forum/viewtopic.p ... ch+service
Derek has put a very detailed procedure on his posting on the second page.
I may have a spare spring but obviously it may not arrive before Christmas :,(
DUCATI 907ie 1992
Ducati Streetfighter 955 V2
Re: clutch springs
Arch, you find all manuals in the downloads thread on top of the P750 forum and the springs are the same on most Ducs (SS, SSie, Hyper, 748, 749, 1098, 907ie etc etc)
The length of new springs is 40-40,5mm.
Re: clutch springs
Pm your address I have some
a330us
Re: clutch springs
Post by a330us »
Hi Guys, thanks for all the responses and the search function and google is the first place I always go to but did not find the specific info I wanted such as torque etc. The second place I always check is the manuals but at least on my computer the paso workshop manual seems to stop at about page 43. My copy of it is missing the english listing for torque valves so only have the German version and meine deutsch ist nicht gut!. I hate to buy a new or set when I just need one. I have a new set of stainless but they're for my ST2. Higgy, I'll PM you and just let me know how much. Thanks for the help. Archie.
Re: clutch springs
I don`t think the torque setting for those bolts is in the manual, you´ll have to look at "nuts & screws in general". If they are M5 bolts like on a Monster it`s 5Nm.
Re: clutch springs
This seems so obvious I must have missed something but .... Why not fit the new stainless springs to your ST2 and use one of the old ST2 springs , or fit the new springs ( as a set ) to the P750 :?
Re: clutch springs
because the ST2 springs are 2.3mm shorter and the wire is thicker.
(I don`t like stainless steel springs as they are usually stiffer and make clutch operation harder)
a330us
Re: clutch springs
Post by a330us »
We'll, i thought about it but redoing the clutch was down on the list with the other things to do on the st and now I know they are too short! Arch.
Derek
Re: clutch springs
Post by Derek »
paso750 wrote:because the ST2 springs are 2.3mm shorter and the wire is thicker.
You could probably fit just two of them. opposite each other with no problem.
Re: clutch springs
:lol: :lol: :lol: :lol: :lol:
Re: clutch springs
Wouldnt have anything to do with them being shorter and thicker ? :P ( how tall are you :P :P :lol: :lol: )
being shorter , they would have less pre-load and being shorter and thicker they would have a higher spring rate ( if thats what you'd call it ) , Id chuck em in and see what happens 8)
Re: clutch springs
how that will affect the clutch is clear
Re: clutch springs
Not to me .The springs being shorter and thicker would make them stiffer , but being shorter they would have less initial preload , and , without calling in Sheldon ( big bang ) Im picking it would be a lot like an ST2 clutch :)
Re: clutch springs
not quite as the ST2 has a different size clutch master pump and clutch slave piston.
