Oil leak
plasmid
Oil leak
Post by plasmid »
Anyone know what that small screw is for?
Looks like there's oil leaking from there.
The prev. owner had some rubbery epoxy over it which came loose.
(128.13 KiB) Downloaded 226 times
Brutus
Re: Oil leak
Post by Brutus »
I've got the same issue.. Also like to know what they do.
plasmid
Re: Oil leak
Post by plasmid »
Brutus wrote:I've got the same issue.. Also like to know what they do.
Is it coming out enough to dribble towards the exhaust header?
Brutus
Re: Oil leak
Post by Brutus »
Yes, it dribbles.
plasmid
Re: Oil leak
Post by plasmid »
Brutus wrote:Yes, it dribbles.
Alright. Same here.
Brutus
Re: Oil leak
Post by Brutus »
Alright. Same here.
Got a picture of it in the past:
ducinthebay
Re: Oil leak
Post by ducinthebay »
I always assumed it was the oil line feeding the head and cams. I assumed it was a cross drilled hole, and that was simply a plug. I have a spare head on the bench. I'll dare to take the screw out and see what's inside. There is some Loctite that seals and holds, but I don't know the part number off the top of my head.
streetsurfer
Re: Oil leak
Post by streetsurfer »
Yes, a sealed oil gallery. I was advised not to try and remove them. Too soft. Sealed mine with rtv after a very thorough cleaning and it hasn't leaked.
Derek
Re: Oil leak
Post by Derek »
As stated above it's a blanking plug for an oilway drilling. They are on all the 2V engines and nearly all of them leak sooner or later. Use a thread sealant to keep the oil in.
plasmid
Re: Oil leak
Post by plasmid »
ducinthebay wrote:I always assumed it was the oil line feeding the head and cams. I assumed it was a cross drilled hole, and that was simply a plug. I have a spare head on the bench. I'll dare to take the screw out and see what's inside. There is some Loctite that seals and holds, but I don't know the part number off the top of my head.
as streetsurfer mentioned, locktite rtv I guess.
Thanks for the suggestions.
