Don't listen to Mr. G!!!!
![:lol: :lol:](./images/smilies/grin.gif)
Oel change and may be change the volume is planed after everything is done. Your values are a good point to start with.900streetfighter wrote:That's looking good Bock, that bike will fly. Suggest you change the oil in multistrada legs, I used 600mm of sae7.5 per leg as per manual. That reduced the travel significantly, before I did that I had clearance issues with tyre/radiator. I raised the rad 20mm also. I have raised my legs in the yokes by 15mm now.
I will measure the lenght from the swingarm bolt to the center of the wheel tomorrow900streetfighter wrote:Your rear arm looks about 50mm shorter looking at footrest/tyre position.
Probably be a hairy ride with 4v power.
Bock900r wrote:Change the Belt's today, fill the Tank. Push the button - running
