dash change over
duc907
dash change over
Has any one changed a dash from kph to mph or the other way around? I would like to know if it's possible.
Re: dash change over
sure, no problem. Remove the very small screw on the rear of the speedometer and pull off the cable of the day trip resetter. Remove the clear cover carefully, then remove the two screws on the rear and take off the metal bracket and at last carefully pull off the angle drive. Take out the speedometer, done.
