new Paso owner
- ducinthebay
Re: new Paso owner
So, BirdDuck, where exactly in the grand ol USA do you live that you can't find Ducati parts?
After e-bay and Craigslist, there's ducati breakers like Nick Anglada https://www.facebook.com/UsedDucatiParts and GuzziTech.
Everything is possible to find on the internet, of course patience is required, and a paypal account. Some parts have taken me several years to find, like my 300mm cast iron full floating Brembo rotors, new in a box.
But if you are interested in a set of stock Mikunis and a stage 1 kit, drop me a line. they are in the garage some where, and I'm on the Dellorto wagon, so I won't be using them.
Re: new Paso owner
its mostly keeping cost down, didn't intend on running into issues of ham handed previous owner :(i am in Utah. how much are you thinking? and would i need manifolds as well?
Re: new Paso owner
inlet manifolds + rubber boots + 2 throttle cables & accelerator throttle + SS choke cable + air filters + the usual small bits
Re: new Paso owner
has anyone used the round slide mikuni carbs? there is tones of those around for cheap. i believe they are mostly off two stroke applications, i thought i have seen them on some other models of ducs maybe the bevel engines?
- Skins
Re: new Paso owner
Phil has made you a good offer. Why don't you do as he suggested, and drop him a line?
Re: new Paso owner
i did..
- ducinthebay
Re: new Paso owner
He will be getting the boots, manifolds, stock carbs, Stage 1 Dynojet kit, and a throttle if I can find it. After owning it for 5 years, and taking up shelf space, I'm glad to make some room
I'll be making some more room in the coming weeks as I might be moving shortly, and need to start cleaning up.
- Skins
Re: new Paso owner
Well done, Phil!
Re: new Paso owner
Found the problem.. 7v to the coils.... Fixed.. 11.7v now
thanks for the nudge on checking the coils.. still want carburetors though
Re: new Paso owner
WOW talk about a different machine now 0_o!
- ducinthebay
Re: new Paso owner
Even better with some Dyna Coils and a relay inline.
Re: new Paso owner
wired it up last night. direct power from the batt to a relay with on with key on. every connection is soldered and shrink wrapped, 8ga wire feeding the coils juice
.. the electric engineer for ducati must have been on acid or something with how all the systems are run :S
Re: new Paso owner
8ga is just a bit over the top
- ducinthebay
Re: new Paso owner
Its not done till its overdone.
Re: new Paso owner
If you're thinking Mikuni carbs, here is what mine look like:
