swingarm chain slider
Re: swingarm chain slider
What's the latest status on these?
- Bock900r
I send Higgy a Hand full of the small and the swingarm slider for testing when I was in the US (fast and easy)
Rüdiger
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
workin on it
Bock900r wrote:I send Higgy a Hand full of the small and the swingarm slider for testing when I was in the US (fast and easy)
Are you in US now? If so, I'll take 3 of the small ones.
Let me know how to pay you.
- Bock900r
I am these days in Germany.
I am not shure that they fit well, may be you have to modify them.
But if I can get some information about the size i can modify the size and build them again
Rüdiger
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
Pictures are in your inbox, take a look and let me know what you need from here
Both seem to fit acceptably. The main slider needs a little stretch but I don't see that as a problem
Soon as Ruediger is ok with it I will post some pictures here
Sounds like the small ones are good to go.Bock900r wrote:I am these days in Germany.
If you have them in Germany I can also give you a DE address,
otherwise US is perfect.
I think they should be tested in New Zealand before they could be considered ok for release
- Bock900r
I think I make some vacation in Feb/March 2015 in NZ. I can give you some if you can wait so longMc tool wrote:I think they should be tested in New Zealand before they could be considered ok for release![]()
Rüdiger
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
In this last picture I just laid the slider on, with a slight stretch it fits just fine
The small units for the centerstand fit perfectly as is
lane1feathers
- year: 1989
Looks excellent
When a run gets made, put me down for one regardless of cost. Thanks for your efforts Rudiger and Higgy.
Lane
89 Dark Blue 906 Paso
and Ken !
It seems to sit a little off center, is it ?
an original:
an original:
- DSCF8803.JPG (45.61 KiB) Viewed 26884 times
- DSCF8804.JPG (44.78 KiB) Viewed 26884 times
- DSCF8805.JPG (42.89 KiB) Viewed 26884 times
- DSCF8806.JPG (36.16 KiB) Viewed 26884 times
- DSCF8807.JPG (25.28 KiB) Viewed 26884 times
- Bock900r
For the first Try is the result OK. With some possible improvement for the next build.
Higgy, how does the small fit?
Rüdiger
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
Bock900r wrote:For the first Try is the result OK. With some possible improvement for the next build.
He wrote above that the small ones fit perfectly as they are.
I think before you change it I need some time to try another swingarm. I have both a 906 and a 750 here as well as the 907 in the pictures
G , it lays just like the original I took off, at least on my 907 spare Have no idea what year it is
