Next up the steering damper.
You can see the rust at the very end of the shaft.I'll remove as much as possible but I don't think it will effect the damper anyway.
I still have to look at the rust on the shaft but it's better...
...except this.
It's a bad photo but basically I got over excited with the wire brush and wore through the brass? cap and out pops a spring."So what does the spring do" and how can I repair it.A dab of solder ( not sure if solder would stick to brass ).Find another cap.I would'nt even know where to start looking for a cap.
Next job is cleaning these.
I don't want to remove them so I'll have a crack with the dremel and wire brush tomorrow.
Andrew
[/url]
[/url]
