mikuni running rich..
Re: mikuni running rich..
we should correct the title to Mikuni running lean
You are the moderator
so current jetting 37.5 pilot, 150 main (dyno jet) 2.5 turns on the mix screw.. going to put some miles on this setup and see how it does
- ducinthebay
Glad to hear you got those dialed in now.
So, in the end, was it worth the change from the Weber?
I know it took me a long time to dial in the Dellortos.
yeah, the weber was scabbed together, leaking and broken.. i am suprised i even got the weber to kinda work...
bike is peppy and responsive, makes my pants tight
