Thanks!
the bearing races are steel and the sleeve is steelAluminium expands more than steel
I forget, anyway I heated the whole assembly and placed a 19mm socket on the exposed bearing and hit it with a lump hammer while holding the assembly in my hand. Which almost qualifies the job as 'by hand'.paso750 wrote:the bearing races are steel and the sleeve is steelAluminium expands more than steel
