Right behind the headlight, using the stock mounting tab. I used a long 6mm bolt, and used a piece of clear vinyl tubing around it for a spacer, and put a locknut underneath the existing nut welded to the frame. I bent back the mounting tab a bit so that the horn clears the headlight shell. Fits tight, but fits. Still has 6" to the fender, so it shouldn't hit the fender under full travel.
Of course, the sound is just lovely. Glad I could find a place to put it on this bike.
