It is currently Fri Feb 22, 2019 6:09 am
 Post subject: 906 Tech FAQ
PostPosted: Sat Dec 15, 2007 2:45 am
I think it's time that we built a 906 specific technical FAQ-thread the way we have been building one in the 750 forum. I'm by no means a 906 expert but can troll thru the threads to find what I think might be important but it's the users of the forum that really know what's unique and needed to populate this FAQ. Please add the past threads that you think will be most useful for others.
DO NOT ADD NEW QUESTIONS IN THIS THREAD
Buying a Paso:
viewtopic.php?f=1&t=705
Voltage Regulator Issues:
viewtopic.php?f=2&t=1959
 Post subject: Re: 906 Tech Faq
PostPosted: Sat Dec 15, 2007 2:57 am
Paint codes
viewtopic.php?f=2&t=1498
 Post subject: Re: 906 Tech FAQ
PostPosted: Sat Dec 15, 2007 7:04 pm
Workshop manual and other downloads:
P906 owner`s manual US version
https://www.box.com/s/05bef79ua99adyspg5do
P906 workshop manual
https://www.box.com/s/mai2335dh4vl43q0efqn
P906 parts catalogue
https://www.box.com/s/anb97obn37pareletpkc
P906 wiring diagram (in colour)
https://www.box.com/s/cuv8nragt3z1vi0pw9pz
P906 wiring modifications
https://app.box.com/s/xzkocz2e7zcomsg40t7f
Weber mod and jetting for the P906
http://www.box.net/shared/q1x77snl9g
coolant reservoir modification
http://www.box.net/shared/ou0yii8jnc
TÜV Bescheinigungen für Alternativbereifungen (german TÜV approval for alternative tires)
http://www.box.net/shared/gq6hrzi9s4
other downloads, reviews, magazine articles etc.
viewtopic.php?f=1&t=1551
Paso 750 FAQs you will find a lot more info there! I.e. alternative clutch slave piston, master cylinder rebuild etc.
PostPosted: Thu Oct 16, 2008 10:51 am
Repair of the Digiplex ECU
viewtopic.php?f=2&t=2813
PostPosted: Fri Feb 27, 2009 6:39 pm
Weber Carb Jetting
viewtopic.php?f=2&t=3090
PostPosted: Wed May 20, 2009 8:55 am
Connecting an ELECTREX regulator/rectifier:
Electrex to original wiring
yellow -> both pink (alternator)
yellow -> red (alternator)
white -> light blue (charging warning light)
red -> red/black & orange (battery +)
green -> black (battery -)
(the brown wire of the Paso wiring loom formely going to the regulator is not used any longer)
Note: If the measured voltage between the two yellow wires from the alternator (which are pink when they get to the regulator/rectifier) is between 50-100V you should wire the reg/rect as shown on the first picture of the instructions hence connect yellow 1 from the reg/rect to one yellow(pink) wire from the alternator and yellow 2 to the other. In this case the red wire from the alternator isn`t used and can be isolated. Install like this if the first wiring instructions don`t work. (To check simply connect a voltmeter to the battery. When the engine is started and the regulator/rectifier is connected correctly the voltage will increase i.e. from 12V to ca. 14V)
https://app.box.com/s/r16ixjegwfl7aq3ybd0c
PostPosted: Sun Jan 10, 2010 10:12 pm
Seat moving back and forth Fix
viewtopic.php?f=2&t=3846
PostPosted: Sat Oct 16, 2010 10:18 am
Engine bearings & seals
viewtopic.php?f=2&t=4369
PostPosted: Mon Oct 14, 2013 9:12 am
Using an AFR meter for carb setup
viewtopic.php?f=2&t=6403
PostPosted: Mon Dec 02, 2013 5:25 pm
906 wiring mods
PostPosted: Sat Feb 28, 2015 6:28 pm
Conrod small end bush
viewtopic.php?f=13&t=6839
PostPosted: Fri May 01, 2015 8:08 pm
Clutch piston
for the 906s with the clutch piston in the clutch cover (not the later ones that have it on the left engine side)
viewtopic.php?f=2&t=7124&p=56530#p56530
PostPosted: Sun Jul 19, 2015 7:40 am
service bulletin gear selector mechanism - all Ducati
https://app.box.com/s/ccqi4o1hoelpn458dffawwf51kiq20cs
PostPosted: Fri Sep 23, 2016 8:41 am
Thermostat repair
viewtopic.php?f=2&t=7515
viewtopic.php?f=3&t=7884&p=61738&hilit=thermostat#p61738
