First post and an ignition problem!
startline
Post by startline »
Firstly hello good to be here and was recommended to try here for an answer, my 1990 900ss has the same ignition as a Paso, here's the problem, all packed to go to the TT and suddenly massive problem, the rear cylinder has stopped sparking at 3700rpm, changed coil leads and same problem still on the REAR cylinder, all leads cables ect are good but as soon as 3700 the rear cylinder plug just stops spark, pickup is working as its a single one so I assume my DIGIPLEX2 is at fault, have I missed anythiing obvious, and if I fit a Paso 750 digiplex will it work ok, sorry to just bounce on with questions but I am desperate to get her running again
Re: First post and an ignition problem!
Not a blocked main jet on that cylinder ?
startline
Post by startline »
No mate the rear plug actually just stops sparking, as I say swapped coils and plug etc and fault remains the same
startline
Post by startline »
Fitted another ecu, sorted :-)
unlikely the ecm was the issue :banghead:
MarkST
Post by MarkST »
higgy wrote:unlikely the ecm was the issue
what's an ecm ?
2004 ST4S
2001 ST4
1987 Paso 750
electronic control module?
Spaggy
Post by Spaggy »
Is anyone aware of a replacement for the Marelli unit on the 906?
A question asked on here earlier was whether the 750 unit was the same. Does anyone know?
One of my 906's seems to have fried the ecu after connecting up the battery the wrong way round (long story!) and I am looking for a solution as the original units are like hens teeth.
Spaggy - Half man, Half machine, Half-arsed Half-wit!
Spaggy
Post by Spaggy »
In answer to my earlier query, I have found more references to this issue on the forum, so am looking at the Dutch option of an exchange unit via carmo.
If anyone has experience of the results I'd be interested to hear.
englishstiv
Post by englishstiv »
Are you aware that the first Fiat Uno coils are similar to those used on a 906 and 750?
This is stated in the 906 FAQ I have not used it myself
Here is one on ebay..........
https://www.ebay.co.uk/itm/VE520039-Dry ... SwBt5ZNeZ7
Which means you might find a similar electrical unit used elsewhere in the early Italian vehicles of various types ???
I think you might find there is an early Fiat car that may use a similar Electronic igniter ( there isn't actually an ECU on the 906)
Here is an example of what I mean but you'll need to find one suitable for your 906.
https://www.ebay.co.uk/itm/CENTRALINA-D ... :rk:3:pf:0
Also you might want to contact this company
https://www.silent-hektik.de/Duc_Digi.htm
DUCATI 907ie 1992
Ducati Streetfighter 955 V2
Derek
Post by Derek »
I'm surprised that none of you guys with a 750 or a 906 have fitted an Ignitech ignition system yet. They are being extensively used among 750/900SS owners to replace the Kokusan units. It's certainly something I would consider.
http://www.ignitech.cz/en/
Spaggy
Post by Spaggy »
Derek.
Thanks for that, but the Kokusan replacement stuff is not compatible with the DigiPlex box, so can't really be used on the 906.
That came from the manufacturer in the last few days.
true but a complete conversion to a Kokusan ignition is possible which would require the CDI units, coils, flywheel, pickups and part of the wiring of a P750, 750S, Monster or Sport. Probably not worthwile unless you can grab all the parts for little money.
Derek
Post by Derek »
Spaggy wrote:Derek.
I'm not suggesting that you convert to Kokusan or a Kokusan equivalent. If you look into the Ignitech website you will see that their modules can be used with practically any motorcycle that has an ignition pickup or crank sensor. I'd be very surprised if one of their modules is not compatible with the 906, replacing the Digiplex with a better product.
Check out the Sparker TCI http://www.ignitech.cz/en/vyrobky/tci/tci.htm
And also Brad Black's blog http://bradthebikeboy.blogspot.com/2018 ... t-for.html
And this pdf from ignitech about replacing the Digiplex on the early 900SS http://www.ignitech.cz/old/english/tci/ ... giplex.doc
