Battery question
H20doctor
Battery question
Post by H20doctor »
I haven't rode my motorcycle in 2 weeks when i went to go start it up dead battery. So... The battery is 2.5 months old.... Did the clock drain the battery ?
2Nd question.... When the bike is running what should the voltage read coming back to the battery from the charging system.... ?
ducinthebay
Re: Battery question
Post by ducinthebay »
Yes, the clock on the 907 will kill your battery. Pull the fuse, or disconnect it. there is a thread that describes what trace to cut on the dash flex circuit. Need to keep the Paso on a trickle charge.
Voltage at the battery should be about 13.4 volts when fully charging.
Cheers, Phil.
H20doctor
Post by H20doctor »
seems kinda crazy that the clock can kill the battery in 7 days ....
if i put my volt meter on the terminals while the bike is running I should read 13.7 volts ? correct
if not , then what do i need to replace on the bike ...?
thanks
nickta
Post by nickta »
The voltage will change depending on the RPM. At idle it will sit around 12.5 volts, and by about 3000 RPM will be up to around 13.5 - 14.0 volts. It shouldn't get any higher than 13.8 or there abouts, but plus or minus 0.2 volts isn't too bad. I wouldn't panic if it was little bit over 14 volts, but if it hit 14.5 or above, then you have an issue with the regulator. If it doesn't go up at all, then the regulator or the Stator is shot. There are a few posts about Regulators and what type etc etc. Different batteries take different charging patterns too. The 907 was built around a Lead/Acid battery. There are now all sorts, wet, sealed, AGM to name a few. I have had a Motobatt AGM battery in mine since I purchased it, and just replaced it with another Motobatt. The original lasted a bit over 3 years, and would still be good now, but that is another story. As a rule, if I don't think I will be riding it for 3 or 4 days, I disconnect the -ve terminal (the shed doesn't have power). Saves time and energy!
The bonus of an analogue clock is they take power to run. Others have replaced the Analogue with an LCD type if you would like to give that a crack?
Cheers.
Nick.
MarkST
Post by MarkST »
nickta wrote:I have had a Motobatt AGM battery in mine since I purchased it, and just replaced it with another Motobatt. The original lasted a bit over 3 years, and would still be good now, but that is another story.
I won't press you on that then Nick as I likely have a similar story involving an Odyssey battery, but must add that I now have a Motobatt AGM on my ST4S and can't sing it's praises highly enough !!
nickta wrote:The bonus of an analogue clock is they take power to run.
How is that a bonus ?
Mark.
2004 ST4S
2001 ST4
1987 Paso 750
I think its spelled Bone Us Mark :thumbup:
nickta
Post by nickta »
MarkST wrote:How is that a bonus ?
Mark.
A figure of speech.
MarkST
Post by MarkST »
Mark.
A figure of speech.
As in 'a bad jam' is a really good tune ?
2004 ST4S
2001 ST4
1987 Paso 750
The clock shouldn`t draw so much power that the battery is flat after a week or two. Imho there`s something wrong.
ducinthebay
That's the way mine is. If the clock is running, the trickle charger will never keep up. I unplug the fuse when not in use.
Cheers, Phil.
Rogero
Post by Rogero »
Alarm, clock and general Italian electrics.....
Plug it into an optimate charger whenever you are not using it. I got fed up replacing batteries - a charger is actually cheaper than a battery!
The clock on mine would not drain the battery in less than 10 - 12 days but the dreaded alarm does in less than a week. So combining the two which I have is hopeless !
Optimate (others are available) is the solution.
Rogero
1992 "Red" 907 I.E.
