I did google a bit. jb weld seems to be a dreamstuff???
?or get a new head
I didn't know that, and it's an interesting theory, but it suggests to me that those metal case savers are totally useless unless they can just stop the motor from turning over when the diameter becomes such that . . .Mc tool wrote:What normally happens when the chain either derails or breaks is that it rolls up on the front sprocket until the diameter is such that it pushes the crankcase out of the way ....
Me too, but nevertheless I have them installed on my 907 and my MTS. You can't be too careful.MarkST wrote:I didn't know that, and it's an interesting theory, but it suggests to me that those metal case savers are totally useless unless they can just stop the motor from turning over when the diameter becomes such that . . .Mc tool wrote:What normally happens when the chain either derails or breaks is that it rolls up on the front sprocket until the diameter is such that it pushes the crankcase out of the way ....
I've only ever had one chain let go on me, and luckily that just split and came off the sprockets and fell down onto the road.
There is a lot of truth in what Hamish says; in that the sort of people who fit them are usually maintenance enough savvy that they never need them anyway.Mc tool wrote:I think the real truth is that if your diligent enough to fit a case saver your probly diligent enough not to let your chain/adjustment get so bad that it could fail.Please don't refer me back to the sprocket bolt thread where I admitted to "chucking a chain thru the cases " ...........that must have been someone elses fault
. Its ( the case saver ) like carrying a puncture repair kit.........your guaranteed not to need it as long as its on board .... soon as you leave it at home you get a puncture
