Another source for M1R-Parts:
http://www.laverda-paradies.de/shop/cat ... 000&chp=60
Guide bushings on 907 ie M1R forks
- JoKing
Re: Guide bushings on 907 ie M1R forks
86` Ducati 750 Paso
96` Cagiva 750 AC Elefant
86` Ducati 750 Paso
does someone have the dimensions of the upper bushes? The part number of the P750/906 bushes is different and I wonder why. I would assume the parts would be the same. In case they are another option for the bushes would be the Guzzi part number 30530520 used on:
MG 1100 Sport (carbed) , 1994 - 1996
MG 1100 Sport carbed , 1994 - 1996
MG Daytona , 1991 - 1995
MG Quota , 1992 - 1997
MG Quota ES `99-`01 , 1999 - 2001
- ducbertus
Hi Gert,
I've a set of new BMW K1100 bushes laying around, waiting to be mounted.
saterday I'll measure them up for you. they ment to go in a M1R of a '91 907
Bertus
Bertus
- ducbertus
Hi, finally have the bushes at hand.
these are ment for a Beemer K1100, but should fit the M1R fork from a 907 as well
upper bushing:#nr: 31 42 2 310 347 Ø outside ± 44.55 mm; height: 19.8 mm
lower bushing: #nr: 31 42 2 310 346 Ø outside ± 41.60 mm: height: 15 mm
regards,
Bertus
regards,
Bertus
