Ohlins rear shock absorber
- Thebenelliman
Does the Ohlins shock absorber fitted to early Paso's fit a 907 ie ? And does it improve the handling?.
Mine has a new ish Hagon unit currently fitted! Not sure if they are good or not?
The Benelliman
1992 907ie
1981 Benelli 900 Sei
1989 Benelli 900 Sei
1976 Benelli 125 Enduro
1981 Benelli 250 2c
1976 Benelli 250 Quattro
1980 Benelli 254
1992 907ie
1981 Benelli 250 2c
1980 Benelli 254
Re: Ohlins rear shock absorber
I had a ohlins shock made by our local agent cost $1500 NZ, worth every penny !Now I am contemplating
finding an ohlins front fork set or having the m1r customized with ohlins internals for around $700 NZ by
the same people here in NZ . The rear also has remote spring preload adjustment (well worth it)makes
preload changes quick and easy.
"keeping the shiney side up"
- MarkST
The Marzocchi rear shock from my 750 has a remote spring preload adjuster too, so I assumed that they all had one.oceanhunter wrote:The rear also has remote spring preload adjustment (well worth it)makes
2004 ST4S
2001 ST4
1987 Paso 750
2001 ST4
1987 Paso 750
while Thebenelliman is talking about the Öhlins shock mounted on the very early P750 models oceanhunter has installed an aftermarket Öhlins.
All P750 shocks had the spring adjuster. Aftermarket Öhlins do also exist w/o.
It fits 907.
Improves handling, do get a proper spring. I got a 52 Nm, + 90 kg driver.
- MarkST
Sorry of course, we're on the 907 section. I wasn't thinking.Tamburinifan wrote:It fits 907.
I realise now that the 907 has the 851 style rear suspension rather than the arrangement on the 750 and 906.
Silly me - apologies all round : )
2004 ST4S
2001 ST4
1987 Paso 750
2001 ST4
1987 Paso 750
it doesn`t. P750/906/907ie have the same rear suspension design.I realise now that the 907 has the 851 style rear suspension rather than the arrangement on the 750 and 906.
- MarkST
Ah yes I've just looked and they sure.paso750 wrote:it doesn`t. P750/906/907ie have the same rear suspension design.
Silly me again :O
2004 ST4S
2001 ST4
1987 Paso 750
2001 ST4
1987 Paso 750
- Thebenelliman
So in conclusion the shock will fit and improve handling?
The Benelliman
1992 907ie
1981 Benelli 250 2c
1980 Benelli 254
1992 907ie
1981 Benelli 250 2c
1980 Benelli 254
it will fit but the question might be if the length and spring rate are identical
- Sergio Desmo
Hello,
as per Ohlins France, dims are not the same. 906 are a bit shorter if I recall correctly.
for the 907ie : S46HR1C1LS (réf. DU907PFP) 1470 euros VAT incl.
cheers,
Sergio
cheers,
Sergio
- MarkST
Fokk that for a game of tennis :OSergio Desmo wrote:1470 euros VAT incl.
cheers,
Sergio
2004 ST4S
2001 ST4
1987 Paso 750
2001 ST4
1987 Paso 750
I put a Paso750 ohlins on my 907 10 years and had contact with tyre on mudguard under ecu with passenger. I had shock rebuilt by Harris ohlins specialist with heavier spring and still had problems.
- Derek
- year: 1994
FYI Mark. The Monster has the same suspension as the 851MarkST wrote:Ah yes I've just looked and they sure.paso750 wrote:it doesn`t. P750/906/907ie have the same rear suspension design.
Penske & Öhlins made for 750 same length c/c as original 907 Marzocchi, FHE.
Original spring 750 Öhlins according to Öhlins Sweden 42 NM, way too soft f most.
W stiffer spring, ride vastly improved, it just works. No problems hitting anything,
haven`t ridden much 2 up though. I assume adjusting preload & setting sag with passenger would
take care of that.
take care of that.
