Paso 20mm swingarm pivot modification
Speedmade
- year: 1989
I found that the Paso has a 15mm swingarm pivot. That is very small especially considering that all other Ducati models since 1990 they have used a 20mm pivot. So I decided that I wanted to upgrade.
This would require modifications to the frame and the bearings in the swingarm.
- Paso-pivot-1_zpsdywrjf4b.jpg (218.68 KiB) Viewed 28924 times
- Paso-pivot-2_zpsicwih7xi.jpg (256.29 KiB) Viewed 28924 times
Speedmade
- year: 1989
Re: Paso 20mm swingarm pivot modification
I found a 20mm axle from some Japanese bike was very close in spec to the Paso pivot.
- Paso-15-20%20pivot_zpsutn3mf60.jpg (298.55 KiB) Viewed 28924 times
Speedmade
- year: 1989
My plan was to bore out the frame but it was impossible to fit in a milling machine. So I made fixtures that allowed me to drill out the holes in steps.
- Paso-fixture-1_zpsyvc7fl80.jpg (309.08 KiB) Viewed 28924 times
- Paso-fixture-2_zpsqzqszulh.jpg (261.25 KiB) Viewed 28924 times
Speedmade
- year: 1989
Measuring the inside of the frame I realized that there would be very little surface area left so I had cups machined that I welded over the original pivot area.
- Paso-pivot-3_zpsgufkslsm.jpg (263.23 KiB) Viewed 28924 times
- Paso-pivot-4_zps1eykjsfg.jpg (238.4 KiB) Viewed 28924 times
Speedmade
- year: 1989
Modifications to the bearings in the swingarm were pretty straight forward. Sourced some new bearings and made a few new spacers.
- Paso-RH-swingarm-2_zpszcuwk47r.jpg (174.96 KiB) Viewed 28924 times
- Paso-RH-swingarm-1_zpsdbjdtfdg.jpg (131.94 KiB) Viewed 28924 times
- Paso-LH-swingarm-2_zpsxxy6b9kl.jpg (173.45 KiB) Viewed 28924 times
- Paso-LH-swingarm-1_zpsdxiwvsbc.jpg (151.62 KiB) Viewed 28924 times
Speedmade
- year: 1989
I had to turn the head of the new pivot down slightly to fit down the frame pocket.
On the other side I had to source a small OD flange nut.
Everything fit so I could install the black plastic caps.
- Paso-20mm-3_zpshsnbowuc.jpg (259.5 KiB) Viewed 28924 times
- Paso-20mm-4_zpsbzbcwbeb.jpg (277.7 KiB) Viewed 28924 times
- Paso-20mm-1_zpsyfkqnbep.jpg (189.63 KiB) Viewed 28924 times
- Paso-20mm-2_zpsmjyfmecd.jpg (215.97 KiB) Viewed 28924 times
Speedmade
- year: 1989
This should make for a much stiffer chassis.
- Paso-pivot-final_zpsugmhmvop.jpg (164.37 KiB) Viewed 28924 times
- englishstiv
I absolutely love shit like this, Well done and brilliant photo's and explanation I think G will be putting this in the FAQ thread pretty soon
DUCATI 907ie 1992
Ducati Streetfighter 955 V2
I love shit like this too , more the psychiatric side of things than anything to do with motorcycle engineering . I mean your obviously no dummie when it comes to making things outa metal but if you really wanted to stiffen up the chasis you shoulda just painted it , any how , nice job ...... if you must
Speedmade
- year: 1989
The frame will be powder coated once I finish the rest of the modifications to install the 999S motor
Oh yeah ! I can so see why you'd want to do that.
Have you thought about fitting the Paso body work to a 999s ?
Hi, soory but maybe I've missed it: how did you solve it with the bearings in the engine case?
Also, what is your main reason to go from 15 to 20mm?
I assume the 999 engine originally uses a 20mm swingarm pivot.how did you solve it with the bearings in the engine case?
Ok, missed that (the 999 engine).
Wow, quit a project!
Assume that adapting the swingarm bolt is the easiest modification
Will be interesting to see the project in progress!
Good luck
Good luck
Speedmade, don`t mind me asking but seeing that the thread of the 20mm pivot is longer I wonder which part of it sits in the frame. Hope you get what I mean. (if it`s the threaded part it could cause radial play, which may be gone if all is tightened up, but still...)
