Hi Fraser,
Are you still after mirror pods? I have a RHS one (when sitting on the bike) which I swore I'd never sell in case I bought another Paso cos they're so damn hard to get, but... it sounds like youre a man in need. It's red and in good cond, with some sanding done in prep for a repaint and a new tang plastic welded on. Its the plastic pod only so no mirror, light or lens. Happy to email you pics.
Hamish
_____________________________________________________89 900SS with: Modified frame, ZXR (Ohlins valve) front end, floating Discs, 888 carbon fender, custom instruments (carbon backed), custom triple clamp & headstock nut, Ducati Supermono carbon fairing, 916 mirrors, LeMans projector beam headlights, 95 900SS tank, DUCATI PASO FILLER!, 944cc Vee Two Aust balanced motor, Keihin Flatslides, 916SPS Clutch, Spaghetti Exhaust, Carbon Mufflers, 95 900ss peg hangers, machined gear and brake levers,
Ducati 955 Corsa (racebike) carbon tail fairing, Carbon hugger, carbon plate surround, custom paint. Standard rear wheel!
Hamish,
Thanks for the offer but I have found some replacments, the ones off a Cagiva Freccia, not identical but pretty good.
There is always a demand for these, so you should be able to get rid of it easilly.
Fraser.
