Batteries
- fasterdammit
Batteries
I just ordered a new battery for my 750, and I went with an AGM (activated glass mat) battery from MotoBatt. Their particular model is an MBTX14AU. Haven't installed it yet, but I've had one in my '97 Monster for years now. That battery has actually outlived a couple different batteries in the Paso - a Yuasa and most recently (and most disappointingly) an Interstate. I got this MotoBatt unit for about the same price I paid for the Interstate a couple years ago, so I'm hoping its performance is more like what I've come to expect from the other one I have.
I guess I'll have to come back in a couple years and follow up. In the meantime, I just thought it was worth mentioning. I've considered going to a lithium-iron/lithium-ion battery, but I've been pretty impressed with these MotoBatts, I figured I'd go with something I knew. I am curious though, if anyone else has gone that route - which brand you chose, and what your assessment is.
1988 Paso 750 #753965
1997 Monster 750
1997 Monster 750
Re: Batteries
I got 3 Motobatt Batteries, the oldest... I lost count of the years and I replaced it ...."just in case" but I still use it as a booster.
The Lithium Batteries... I got friends very hap[py with them, any good manufacturer will be OK, provided that it is a "serious "name.
These batteries could be dangerous is the quality of the cells is not good; there is also the issue of the recharging, usually these batteries have a controller board that controls the recharging process making sure all the cells are balanced (all cells end with the same voltage after recharging).
The Lipos are quite weird, on very cold weather they might have issues , so before cranking you will need to leave the lighs on for fw minutes so the Lipo warms up and then can release all its power.
The beautuy is the weight, but I am not sure if I like to have a lipo under my tank or seat...
- whitepaso
Re: Batteries
I am on my second AGM battery. The first was installed in 2009 and lasted until last year. Always kept it on a trickle charger and always disconnected the ground wire when not in use because I ride so infrequently. Unfortunately cannot remember brand name. My current is from NAPA and is identical to the 1st. Seems to be doing fine with same charger/disconnect routine. I like this type, always plenty of energy to start the motor and they seem very durable.
From what little I know about Lithium batteries and their inherent need to be controlled by software that typically rides along with the battery and interfaces with the "device" it's installed in for both performance, discharge and recharging reasons, I don't know enough to want to experiment with them on an unmatched vintage vehicle.
- fasterdammit
Re: Batteries
I usually use a Deltran Battery Tender for my batteries, so with this new battery, I also purchased a fused quick-disconnect plug and plug+play voltage reader. I can leave the plug hooked to the battery and zip-tied to the frame, so I can charge the battery on the bike - but I can also plug the voltage reader dongle in (or just leave it; it only stays on for 10 seconds) for a quick check of the battery life.
I should've done this years ago.
Here's what I bought:
Quick disconnect harness with ring terminals
Quick disconnect voltage reader dongle
The Deltran battery trickle charger uses that same plug. I noticed there's also other options you can get, like a USB port, etc.
1997 Monster 750
1997 Monster 750
Re: Batteries
Good choice that you didn't. Anyone who considers a lithium or also a gel battery should read the spec sheet and the charging requirements. These are quite different with the consequence that you'll have to connect an external charger on regular basis because just from riding the battery will never fully charge leaving you with only one real advantage which is that it discharges slower than a standard battery.I've considered going to a lithium-iron/lithium-ion battery, but ...
Stepaso
Re: Batteries
I've got a 1988 Paso LTD, I had a charging issue which I fixed, I installed a voltage monitor that's used for solar panels so I could tell voltage in & voltage out, it works really well, I've got two voltage meters one on the battery and one from the generator, you can watch the whole thing charging the battery after startup drain and then balancing the battery etc .....
I highly recommend this, stephen@kiwisail.com if anyone has any questions
Stephen
Stephen
koko64
- model: other
- year: 1999
Re: Batteries
A volt meter is a good thing.
Batteries rarely let you down of themselves unless they're cheap crap. Its more likely faulty charging systems and neglect that let batteries down.
The compatibility of regulators is an issue in regard to LiFePo4 (lithium) batteries. In reality the lithium batteries are 13 Volt batteries. A healthy regulator is paramount.
I have used Shorai lithium batteries and got 10+ years out of them. For AGM batteries I use Yuasa or Motobatt.
If you buy a cheap regular battery the risk is that it will fail easily, but buying a cheap lithium battery runs the risk of failure and burning your bike down if your regulator goes rogue.
2013 M1100 Evo Street
2004 GSXR750 Track
2004 GSXR750 Track
Re: Batteries
Like Whitepaso I got my battery from NAPA. It's an AGM made by East Penn Manufacturing in Pennsylvania. Excellent quality. Been using the same brand in my 1983 Laverda for years.
1973 BMW R75/5
1976 Suzuki GT185
1983 Lavarda RGS 1000
1988 Ducati Paso 750
1995 BMW K75
1976 Suzuki GT185
1995 BMW K75
Re: Batteries
also known as DekkaEast Penn Manufacturing in Pennsylvania
I also use Dekka AGM
koko64
- model: other
- year: 1999
Re: Batteries
Yeah they have a good name for durability. Found them hard to get lately.
2004 GSXR750 Track
2004 GSXR750 Track
Re: Batteries
