starter rebuild kit
Derek
Re: starter rebuild kit
Post by Derek »
Finnpaso wrote:I checked just, that 907IE, ST2 and ST4S have samekind starters and 750 Paso different one. But whatkind 906 have? P750 or 907IE model? My quess, is that, 906 and 907 have samekind :wacko:
Part numbers:
750 Paso / 067050800
907IE, ST2 and ST7S / 27040011A
750 Paso starter also looks different compared to 907IE (in spare part catalogues)
Antti
Yes, the 906 and 907 have the same starters. They are basically the same 90cc engine. The Paso 750 though uses a Pantah engine and, as I understand, has a shorter starter and the later starter won't fit.
Derek, do you know? I seem to recall that some Ducati starters have a pinion with a different number of teeth and are therefore not interchangeable.
