speed Ducati 907 iE
dfarias
speed Ducati 907 iE
Post by dfarias »
Dear Ducati group,
Some one know why my bike can not run more than 80 mph?
I tested this in all speed, apparently don´t have any problem.
Any idea?
thank you so much.
David.
Re: speed Ducati 907 iE
need more info, Whats your tach read in top gear at 80 ?
Post by Tamburinifan »
When was was it last serviced, belts valves etc?
How many miles since new fuel filter?
Been stored for years?
Sergio Desmo
Post by Sergio Desmo »
Fear ?
Speed limitations ?
right wrist premature arthritis ?
:lol:
dfarias
Post by dfarias »
higgy wrote:need more info, Whats your tach read in top gear at 80 ?
Hi higgy, thank you for your answer,
I touched this speed in gear 6th,is the only information, turn on ok, the engine no fail, I mean it no make explosions, and work well in all gear (1st, 2nd, 3th, etc).
The problem this is a feedback system and I don´t know in wich part begin to check.
dfarias
Post by dfarias »
Tamburinifan wrote:When was was it last serviced, belts valves etc?
Hi Tamburinifan, thank you for your answer.
The timing belt, belt tensioner, air filter, fuel filter, fuel pipe are new.
I use it 1 day a week, only for test.
What happends when you reach 80?
Does it stutter, cut out or what?
And what RPM do you see at 80?
Turin
Post by Turin »
What are your sprocket sizes? Is the one in the back really large?
1986 Guzzi BOTT Racer
Derek
Post by Derek »
Turin wrote:What are your sprocket sizes? Is the one in the back really large?
Or so small so that it won't pull the high gearing?
Not sure what you mean,please explain feedback system
Do you have a non stock ECU ? Installed an O2 system ?
If you have the stock ECU it may just need some tweaking and you can find everything you need here in the documents section or just ask many herre can help you besides me you made need to set up the TPS and do a sync of the throttle bodies or you could have a sensor issue
What about the exhaust, is it original? An open exhaust w/o rejetting or remapping can cause the engine to run lean. It'll noticably reduce top speed.
dfarias
Post by dfarias »
Tamburinifan wrote:What happends when you reach 80?
???? And the answers are? All questions above from posters are relevant, we can`t help without answers.
And explain what you mean by "feedback system", fuel return or what? You think you suffer from fuel starvation?
