Rear brake pump
Mirinn
Rear brake pump
Post by Mirinn »
Hi, can you tell me which rear brake pump would fit the 906 Paso?
I wanted to rebuild only the piston, but I have not got anywhere in the EU, I will probably have to replace the whole brake pump
Derek
Re: Rear brake pump
Post by Derek »
Brembo seals and repair kits can be bought from KTM dealerships. Make sure that the model has the same master cylinder.
https://www.motorcyclespareparts.eu/en/ ... ol-duke-94
Mirinn
Re: Rear brake pump
Post by Mirinn »
my piston is 11mm and they do not have a supply
Re: Rear brake pump
you can still find the complete pump.
https://www.stein-dinse.biz/Brembo/Fuss ... rettyPhoto
Mirinn
Re: Rear brake pump
Post by Mirinn »
it will be it, thank you :thumbup:
Derek
Re: Rear brake pump
Post by Derek »
For information. Repair kits for the Brembo PS11 rear master cylinder (and many more) are available from Gutsibits in the UK.
https://www.gutsibits.co.uk/pr/TheShop/ ... e=4#topbar
Mirinn
Re: Rear brake pump
Post by Mirinn »
I ordered here, thank you for the tip
https://www.stein-dinse.biz/Ducati/Brem ... 16254.html
I have a mounted brake and it works as it should :)
