What is this part of carb and how can I prevent it from leakage? When turning the gas handle this part moves and starts to drip a little gas over time...
Gas leakage from carb, 750s
- EA325046-86C7-41F2-9288-110910861B13.jpeg (131.58 KiB) Viewed 10015 times
Re: Gas leakage from carb, 750s
That's the accelerator pump. There's a membrane behind the cover that may need to be replaced.
http://stores.ebay.com/ALFA1750S-CARBUR ... ORE?_rdc=1
https://www.ebay.com/itm/WEBER-40-42-44 ... 43a165f925
Got one from local bike part seller. Hopefully it is the right part
All Weber DCNF's use the same one
That fixed it! Great, once again thanks to you guys
This also fixed the rushing issue and bad idle running I had in my other post.
