It is currently Tue Aug 04, 2020 11:33 pm
 Post subject: Weber adjustment
PostPosted: Thu Jun 07, 2018 7:32 am
I can not set up Weber carburetor on 906 Paso :banghead: , please advice
 Post subject: Re: Weber adjustment
PostPosted: Thu Jun 07, 2018 7:33 am
give us some more info. What's the problem?
PostPosted: Thu Jun 07, 2018 7:38 am
does not go well into the speed while riding, when I squeeze the clutch while driving and I take the gas, the engine goes out. Also, when taking gas, it shoots into the exhaust
PostPosted: Fri Jun 08, 2018 9:01 am
imo check everything around the carbs first. I.e. measure if the coils get the same voltage the battery has, check the rubber boots below the carbs for hairline cracks and verify there's also no leak air at the carb manifold/cylinder head connection. Then check valve clearances and if all that is ok have a look at the carbs float needle jet.
PostPosted: Mon Jun 11, 2018 6:56 am
Thank you, I'll try to check it out again
PostPosted: Mon Jun 11, 2018 8:48 am
while you're doing that also check if you still have the Y piece in the fuel line with the return hose to the tank. Not having that can cause the carb to overflow and also puts stress on the pump.
