All depends, what modifications You have made to Your 907IE ? If only K & N and little open exhaust, then FBF can do that job, but if more, then need special one, so FIM chip WITH AMB and tune with flat top pc with FIM software is best result. Surely then need to weld Lamda sond connectors to headers and Dyno bike.... All depends, as You know.... at least money!
Btw, what is that Your "racing eprom" ???? Did You put it 180 degrees wrongly way? Easy to destroy it that way, cause supply voltage goes then totally to wrong pins and same with grounding
Btw, i have one FBF for sale, what is not yet in classifield section. If someone is intrested, PM to me.
907IE -91 red/metal grey
907IE -91 red
